We migrated to Creo Elements/Pro 5.0 M140 on Monday and I've been experiencing an issue with dimensions not showing on drawings. I've tried every iteration of Show Model Annotations conceivable and they do not show up. They don't show up as Annotations under the view and aren't erased. I've had to resort to drawing created dimensions for them, see the attached jpg.
Has anyone else encountered this issue? This has happened on multiple drawings of different parts and assemblies.
Not sure if this is the solution because you mention they're not erased, but it's worth a try.
While in the Annotate tab, try going to the drawing tree and expanding the annotations node for the view in question. Pick through the dimensions you see there to check if the missing dims highlight. If so, you can right-click and pick "unerase".
One of the stupidest changes PTC implemented, IMO.
In Reply to Anthony Troupe:
I had already tried doing that and they don't show up in any other view as erased annotations. It's like they don't exist in the drawing, at all.
In Reply to Don Senchuk:
In Reply to Anthony Troupe:We migrated to Creo Elements/Pro 5.0 M140 on Monday and I've been experiencing an issue with dimensions not showing on drawings. I've tried every iteration of Show Model Annotations conceivable and they do not show up. They don't show up as Annotations under the view and aren't erased. I've had to resort to drawing created dimensions for them, see the attached jpg.
