Hello, I've been trying to find those files all around Windchill and my local PC but didn't succeed in that. Where does creo simulate save mesh files?
It took me a while to figure out where it's actually saved. However, it's not in the folder you showed.
I tried following the method you described, but nothing appears in that folder.
I did manage to find the file in Windchill, though. So it seems no separate local files are created on the PC — everything is always stored as part of the cache in Windchill.
Thank you for your answer.
Hi @ilyachaban,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
You could add things like the product version, places you've already searched in, etc. Adding these additional details may help in receiving more meaningful response from other community members.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Thanks & Regards,
Vivek N
Community Moderation Team.
Hi @ilyachaban
If you have not changed the default settings, it is in a subfolder of your working directory. The name of the sub-folder matches the name of the analysis.
Hello @ilyachaban,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
