Creo Simulation Live - cloud trial questions
bedmonds
Please ask your questions here.
5 REPLIES 5
BostjanB
(To:bedmonds)
Hello!
I would like to try Creo Simulation Live on cloud wersion.
I registered with the form several times, but I did not get any links for the session.
What should I do?
Boštjan
bedmonds
(To:BostjanB)
Hi Bostjan - one of our reps should have reached out to you already. Can you please tell me where you are located? I will ask a team member to follow up directly with you.
BostjanB
(To:bedmonds)
I thought that this is clearly written with the registration form . . . anyway, Magneti Ljubljana d.d. Stegne 37, 1000 Ljubljana, Slovenia.
Regards, Boštjan
bedmonds
(To:BostjanB)
Thank you, Bostjan. I don't have access to your form completion, but I've asked Rimma to follow up with you directly asap.
Greetings,
Same here, I work for a reseller in South Africa, I can run Simulation Live on Creo 7.0.0 but not on 7.0.2. I wanted to showcase the Simulation Live Cloud access to a potential customer.
I did fill in the form.
