would you please let me know where should I go to study NC Machining for Turning --> Lathe & Mill-Turn tutorials?
we just bought a CNC Turning Center - EMCO MaxxTurn 65 and need some support.
I already browsed PTC Online University Creo 2.0 where I knew they have great tutorials in the past but I couldn’t find any right now - it seems they change the site and remove them compare to a year ago.
Any suggestion, connection or contact will be very appreciated. We must run this new machine quite soon.
Thank you in advance.
Sorin
Hi Sorin,
Here are some resources:
Creo Parametric Help Center - Manufacturing:
http://www.ptc.com/cs/help/creo_hc/creo20_hc/pma/aux_files/manufacturing.html
Here is some information that Technical Support has put together for general questions.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS110857&source=tssearch
For training, there are classes available through PTCU by searching by “Milling” or “Turning” under Creo Parametric 2.0.
https://precisionlms.ptc.com/app/pages/Login/?o
• Milling (WBT-3908-0): https://precisionlms.ptc.com/viewer/course/en/8065826/page/8065828
• Turning (WBT-3925-0): https://precisionlms.ptc.com/viewer/course/en/9934179/page/9934181
• Advanced Turning and Multi-Task Machining (This one does not seem to have a WBT#): https://precisionlms.ptc.com/viewer/course/en/12288703/page/12288705
Hi Sorin,
Hi Clint,
Sorry for my late thanks, but your help was great, Precisionlms have awesome mill-turn tutorials. Many, many thanks.
Be blessed!
Sorin
