Creo4.0 convergence plots
346gnu
Does anyone know how to control what is displayed in the graph?
I opened the run status again and the graph displayed Deflection vs load
I couldn't get back to the norm vs iteration
I couldn't see a right click or anything in the menus,
I re-opened the run status a 'random' number of times and it went back to deflection.
I must have missed something.
5 REPLIES 5
346gnu
(To:346gnu)
Then I managed to get my axes to go green somehow and no graph.
rrabe
(To:346gnu)
Hello
I´m just testing Creo 4.0 M70 in Windows 10 and I had the same question:
_ Have you found a way to control the plot that appears in the Run Status?
Also, I understand what you mean with the "green axes". I also got this strange behavior!
However, I found something even worst.
If you get it when running simulation, you will also have problem if later you want to display your result as a "graph".
The graph is empty and Creo does not actualize the graph scale whatever the measure you choose. It keeps showing only “time” scale in both axes.
Its looks like a bug. I´ll try to pay attention how to cause it and contact PTC.
It may be related in switching CAD models during simulation or similar event that make you leave the simulation – not so easy to reproduce.
In case that your Graph is empty, re-starting Creo (not only the model) usually solves this problem.
rubenvillarreal
(To:346gnu)
I don´t even have that plot! (check image)
Did you try to plot it as a result window?
346gnu
(To:346gnu)
Still doesn't work
346gnu
(To:346gnu)
Creo 7.0.5.0 W10
