Hi
What parameter in config.pro specifies the template folder path for Creo Simulate?
Default Result Windows Templates
Thank you all in advance.
According to the info I have, for Creo 9, the option to set is
sim_pp_template_dir
sim_pp_template_dir
Thank you!
