To all
I created some measures (RMS disp, RMS accel - that sort of thing) but when I look at the results I see nothing . These do not appear in the list.
I also would like to create a PSD response graph but again I am getting nothing.
The analysis ran succesffuly and all is Ok. I just do not get measures
Hi @JXBWk ,
Do your measures show that they are valid for dynamic random? (see images below)
If yes, then did your normal modes analysis have stresses/rotations/reactions turned on? (it should warn you if you do not)
Did you check the box on the output tab for RMS displacements and stresses? (I am not sure about this one but usually I just check the RMS levels using this, not with measures)
Finally, did you specify the number of output steps on the output tab or use automatic? Maybe a problem there?
Hi @JXBWk ,
tha nks. I see the difference now
... and now I see even clearer. RMS levels are a single number so they will not show up as a PSD plot and so will not be available to plot.
If you make a RMS measure it will only show up as a single value in the run summary as shown below. To get a PSD style plot you need the "at each step" option.
