I have been performing mechanism analysis for some time but I usually use align two entities and mate two entities option when creating initial point snapshots, either method gives me same results. I wonder what's the main difference between two options , I would like a very good use case to differentiate between them both.
Hi @Lewis_Maina_M,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
More information:
Basically am trying to understand differences between ALIGN TWO ENTITIES option MATE TWO ENTITES option when you use drag feature to create snapshots for several named positions. This is usually applicable when performing mechanism in Creo to define initial start point of your mechanism not only dynamic mechanism , also static an others.
Why am asking this:
I usually use either option and results is the same , is there a specific scenario where its a MUST to use one option and not the other?
Hello @Lewis_Maina_M
The Creo Help Center describes the functions of each constraint in this window.
Hopefully this detail helps you to understand the difference better.
Mike
