Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Is there a drawing comparing function in Pro-e? I have had a request by our quality dept to check into this.
Rick LyBarger Jr. Design Draftsman Husky Corporation 2325 Husky Way Pacific, Mo 63069 636 825-7221 636 825-7300 Fax
This electronic mail message contains information that (a) is or may be LEGALLY PRIVILEGED,CONFIDENTIAL,PROPRIETARY IN NATURE, OR OTHERWISE PROTECTED BY LAW FROM DISCLOSURE, and (b)is intended only for the use of the Addressee(s) named herein. If you are not the intended recipient, you are hereby notified that reading, using, copying, or distributing any part of this message is strictly prohibited. If you have received this electronic mail message in error, please contact us immediately at (800) 325-3558 and delete the message completely from your computer system. Thank you
This email has been scanned by the MessageLabs Email Security System. For more information please visit This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Under Analysis, Compare Drawing in Wildfire 3.0. You will have to have a different name for your drawing "before and after". We've used this from time to time - it works, though I wish the interface was better - Compare Part works a lot better in my opinion
