Edit sketch and references are not updating or failing, just staying in the same location not moving
Proe Users,
I have recently switched to W3 (M090) from W2 and I am noticing a major problem! Every time I edit the location a of a circle the sketch moves but all other geometry referencing that circle stays in the previous location and does not fail, does not warning me that anything is wrong, and will not update. This is ABSOLUTLY UNACCEPPTABLE behavior. When I constrain references I expect them to stay tied to the features I reference or warn me something is not updating for some reason, hence the "P" in PTC that stands for parametric, If I didn't want this to happen I would use AutoCAD or if I wanted it to happen only sometimes I would use Solidworks. Pre-W3, the ability for Proe to maintain references in such a robust manor has been the #1 reason I believe that Proe is the best CAD product that is on the market. I certainly hope that this issue is resolved in build M100, I don't want to have to update 20 sketches every time I edit my original sketch layout driving my design. Anyone have any info on this? See attached image for clarification.
www.prioritydesigns.com This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
