Dear Community
I am using Creo 8.0.8.0.
I would like to export or extract simulation results in a easy way into a csv-file or other file format that can be imported into excel.
Currently I am facing following problem. I have done a Contact Analysis using 2 time step and I also wrote.
In the post processing I created a graph using a measure (force) vs. time. Somehow I cannot export the graph. Also I cannot plot two measures (e.g. bolt force vs. input force) that shows their correlation over each time step.
Somehow Creo creates several output-files and also folder of each time step but I am not able to find how to use this file and to extract the information I am interested in.
Below you find a screenshot of the graph I would like to export into a CSV or other format.
Within the post processing tool (Simulate Result) I was not able to export a CSV file. It was only possible to create a "rwd" file.
Following I did:
- Nonlinear (Contacts) simulation
- Output: 6 Master Steps (of each of them "Full results" have been written out
Is there a way to read some of the output files to get the information I need e.g. res-file?
Does the res-file includes the measures of each time step?
Thank you for your support.
Somehow I cannot upload the screenshot.
Hi skunks
Thank you a lot for the solution. Somehow the xlsx is not created but the grt-file which already helps me a lot.
Thank you!!
I found this topic due a point that you described - I also could not export the result as excel file (as I am doing since I started with this PTC product) - but had no problem to export it as .grt.
Copying the values from .grt to excel cause some formatting problems (it is not recognized as a number) what is easy to solve but causes unnecessary more steps.
As I wrote, I am using "save as excel" for the graphs at long time but now there is nothing stored in the working directory -and I am using Creo 10.0.4.0
This is not normal - we should be able to generate - and store - .xlsx files in the working directory, but it is not happing.
First I thought that was a configuration problem with my Creo - but now I see other people describing the same issue!
about the results not being exported as excel file, this seems to be a know issue and related to MS office security configuration.
For more details see Article - CS413767 - Exporting result to an Excel file from the Graph (Chart-Tool) feature is not working in Creo Parametric.
_ This is affecting all Creo versions since 7.0
The official solution is:
_ "Temporarily disable any security labels or sensitivity labels applied to MS documents on the affected user's computer" - what in may case is a no go and not allowed.
_ Export the graph as tabular file format (.grt)
As it seems, until now exporting the graph as .grt file is the unique solution - although I dislike this formats since my excel has problem to right interpret numbers from this file having points or coma. A lot of manual correction is necessary.
Do not expect to have a good solution soon... If you use security labels or sensitivity labels applied to MS documents, this Creo function is gone...
Hi Skunks
Can you please confirm that you are able to save - and find - the plot exported as excel file?
Like JW_4259374, I cannot find the resulting excel file in the working directory.
I never had this problem before and I am using this export function since ever!
So far the problem appeared in Creo 8 and 10. No idea when this started and if is user specific - I mean, related to a specific configuration that was changed and the user is not aware.
Thanks!
