Hello!
I would like some help or a tip from the community.
Is it possible to add a frequency data as input in a fatigue analysis in CREO Simulate?
I am analyzing a hypothetical case of an "I" profile beam with a load of 5000N and a frequency of 1Hz.
Has anyone encountered an identical or similar case?
Does anyone have any tips on how I can add this input data to the analysis?
I'm using Simulate on CREO 8.0
Thank you.
in Fatigue Advisor the load amplitudes have no time or frequency reference
I use Fatigue Advisor as Creo 2
Tank you Skunks.
I'll try it.
