The problem is when firewall is OFF, all my applications like parametric, simlute etc are running but as soon as I turn it ON there is a warning messege that "License server is down or not responding" .
But I want my firewall to be turned ON and use the apps. Is there any setting for this . Please help.
Thank you Martin for reply,
I tried your method but could not modify license.dat,(Access was denied)
What I did was I added exceptions in firewall for lmgrd.exe and ptc_d.exe and it started working. ![]()
in current Windows version I use the following method:
1.]
On license server I install FLEXnet 10.8 (available on Proe WF5 DVD)
2.]
I modify license.dat to contain two lines similar to the following ones
SERVER servername PTC_HOSTID=serverMACaddress 7788
DAEMON ptc_d D:\PTC\flexnet\x86e_win64\obj\ptc_d.exe D:\PTC\flexnet\licensing\ptc.opt port=7789
3.]
I restart license server.
4.]
I define Inbound rule in Windows Firewall to enable communication via 7788,7789 TCP ports.
Martin Hanak
you used the second possible method. You are the winner
Martin Hanak
