Flow analysis running past iteration limit?
GV_10691043
Does anyone know why a simulation would run past the iteration limit? I had a run going yesterday set to the default 500 limit, and I didn't realize it ran right past it. I manually stopped it at the 516th iteration. I double checked and the limit was set correctly, so what could have caused that? Thanks!
tmoser
(To:GV_10691043)
I have stopped a run and then restarted. After the restart, the analysis ran for the full number of iterations again. So I had total iterations of 500 plus however many iterations had been done when I stopped the run and restarted it.
GV_10691043
(To:tmoser)
I don't think that happened yesterday, but I don't remember for sure. I did start a continuation run at the third iteration today, so I'll see what happens when that finishes in few hours. It's the exact same model with some parameters changed, so I guess if it goes past 503 there's definitely something else going on. Otherwise, I have no idea.
cfdgeek
(To:GV_10691043)
Hi
Assume you meant creo flow. You can change it under common module of the physics. It is in the simulation tree. Every time you click continue run, it counts from 0 again. It is a limit for each run not global iteration numbers. thx.
