I need a fluid flow/thermal analysis package that can do the following
for water flowing through a complicated heat exchanger:
Must Have:
- Calculate Pressure Drop
- Perform thermal analysis (convection) based on the flow of the fluid
Would be nice:
- Show velocity profiles throughout the model
What works well with Pro/E?
Are any of the packages out there associative with Pro/E or do you have
to recreate your analysis model each time?
What is easy to use but also gives you accurate results?
What is the cost for such a package? (I would only need one copy)
Thanks for the help, I will post a summary.
