Highlighted snap line(s) cannot be regenerated
sk-10
2-Explorer
I keep getting the warning message "highlighted snap lines can not be
regenerated" in drawing mode for some of our template models. However, no
matter what I do, I cannot see any snap lines, highlighted or not. Is there
some way I can get these snap lines to be visible so I can figure out why
they can't be regenerated?
currently im working on creo 3.0 mo90.
SARAVANAN K
mbonka
(To:sk-10)
Hello SARAVANAN K
in my opinion snap lines where created in related to geaometry that is no more present in your model/drawing.
See following pictures:
1. Snapline created to Object/geometry
2. Square geometry was replaced with circle
From my praxis: Snaplines related to VIEW are much more consident that snaplines related to geometry.
Hope it can helps
Regards
Milan Bonka
mbonka
(To:sk-10)
Hello SARAVANAN K
Hope it can helps
Regards
Milan Bonka
Pieface
(To:mbonka)
I realize this is a past thread.  I found a good solution to locating snap lines.  While in a drawing do a CTRL-F or choose the Search Icon.  Search for "Snap Lines", by History, All.  Select them all and add them to the collector.  Close the Find Tool.  Select "DEL" or Right Click and Choose Delete.  If you have a multi-sheet drawing only snap lines found on the current sheet will be deleted.
