What I'm trying to do is:
Are either of these things possible in a nonlinear large deformation analysis? What are the workarounds I need to do?
I'm aware of the workaround using a spring or beam for Creo Simulate's limitation of not being able to apply a constraint to the dependent node of a weighted link as described here: Rigid link versus weighted link - PTC Community However I've found that if I try to use a beam or a spring in a nonlinear large deformation analysis it tells me I can't use them, so I'm a bit stuck on how to proceed.
Also a general question. When I'm trying to find information in the documentation about limitations of features with different types of analysis, I can't seem to find anything. So I end up having to find out what options work together by trial and error. Have I overlooked a section in the documentation which explains this stuff? Or is there some trick to navigating the documentation to find detailed explanations of the different features and limitations of their use?
Thanks, Pete.
but not possible with weighted links
Hi Skunks, thanks for looking at this and the provided example. I must have made a mistake with my test model as I thought I'd setup that model as per what you've done in your example. Revisiting that model it does work, so that's really good. Shame there's no workaround for weighted links in this type of analysis.
Thanks again, Pete.
