How to create parameters with Units with Modelcheck?
ZANET
8-Gravel
I am using Creo Parametric Release 11.0 and Datecode11.0.5.0
I use ModelCheck for create parameters in creo prt.
Is it possible to specify units?
this is the line in MC for my parameter:
PRT_PARAMETER DIAMETER REAL EQ 10
And I need that the parameter created has mm as units.
Because in windchill this parameters is a type: Real with units
Van_AG
(To:ZANET)
Define restrictions for the parameter in the restrictions list
for example
{ Name = DIAMETER
  Type = real Length
  Default = 10.0 mm
  Enum = {10.0 mm, 12.0 mm}
Use restricted_val_definition config option to enable the restrictions list.
Then create the parameter by MC
VladimirN
(To:ZANET)
Similar question - "How to add parameters with units using ModelCHECK?": https://community.ptc.com/t5/3D-Part-Assembly-Design/How-to-add-parameters-with-units-using-ModelCHECK/td-p/394033
That question is 10 years old... still not solutions??
Van_AG
(To:ZANET)
for example
{ Name = DIAMETER
  Type = real Length
  Default = 10.0 mm
hadardor
(To:ZANET)
Van_AG
(To:hadardor)
Article CS299858 is about something else.
It's about how to create a parameter with the name of units in the value.
Not a parameter with units of measurement.
