How to model different spring stiffness for loading and unloading in Creo Mechanism (MDO)
SK_13639906
In Creo Mechanism (MDO) motion simulation,
I would like to use different spring constants for the loading and unloading (return) directions, in order to represent spring hysteresis.
Is there any way to simulate this behavior in MDO?
If not directly supported, what is the recommended workaround?
remy
(To:SK_13639906)
Hi
just thinking out loud : did you try and use a parameter, relations and analysis ?
the stiffness could take a value depending on the direction.
the stiffness of the spring can be set a parameter
that parameter can be define by a relation
that relation could give different values to the stiffness
now you need to find how to pick the direction
maybe try with measures
my two scents
