I am using Creo Simulate - Release 3.0 (connected) 3.0 M070
Looking for guidance on how to use stress and/or deformation results from an assembly of parts... and then use those as an input to a more detailed analysis of each component piece part.
Thanks for confirmation. Please close the tread then.
You may add measures to get more details.
Thanks for your reply-
I am familiar with measures but don't believe the ones I really need are there?
I could measure displacements on each part and use a forced displacement constraint at appropriate locations on the piece part BUT that won't let me optimize that part because any geometric changes would negate the validity of those displacement constraints.
I could measure stress, but stress is not an input for a new analysis and is related to displacement.
I think I need to measure "forces at the boundaries of the part of interest???" but one can only sometimes get valid forces at the constraint locations of the original assembly I think.
I've never done this before: If you have more insight into how I can do this, I'd appreciate it. Thanks.
Found: https://www.ptc.com/en/support/article/CS46635
How to measure resultant force for a specific component in Creo Simulate
Create a measure as following steps:
1. Measure under Home tab > New
2. Select Force, Resultant as Quantity
3. Select Components as Spatial Evaluation
4. Select the first component and second component.
That certainly looks like the correct answer, thank you. I don't know how I failed to find it when looking around. I seem to recall that the only force resultants I could get from Creo measures where at points that were constraints for the assembly. I'll take a peek as soon as I can. Thanks very much.
