I am new to Creo simulate. I just had question in my mind whether we can import mesh file from other workbench and run analysis in Creo?
Gajanan
As far as I know not possible using Creo Simulate. You can use Creo Simulate FEM mode to set up an analysis in creo and the export it to ansys to run but not the other way around. P elements vs H elements.
Hope this helps,
Don Anderson
