Importing x_t files causes Creo 9.0.7.0 to Crash
NL_9872257
I am running Creo 9.0.7.0 on Windows 11 24H2.
I am trying to import x_t files and it causesCreo stop responding and crashes. Here is my traceback.log file:
The trace creation timestamp is: 수 12 11 11:40:52 24
The executable build timestamp is: 월 11 20 21:36:19 23
The datecode is: 2023374
The pro machine type is: x86e_win64
The process ID is: 37268
The traceback type is : CRASH
The logger exit status is: 00003
The Trail is: trail.txt.75
The release is: 9.0
The product version is: 9.0.7.0
The product title is: Creo Parametric
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 40172.
 Pls help me! tysm
Similar issue - "Importing Parasolid (x_t) causes Creo 5 to Crash! Help!": https://community.ptc.com/t5/3D-Part-Assembly-Design/Importing-Parasolid-x-t-causes-Creo-5-to-Crash-Help/td-p/612233
NL_9872257
(To:VladimirN)
Thanks @VladimirN let me try it
BenLoosli
(To:NL_9872257)
You may also have an issue with date code compatibility.
Is the .x_t file generated from a version of NX that is compatible with Creo 5?
NL_9872257
(To:BenLoosli)
I have no idea, but i think my x_t file not compatible. So i skip this file now. Thanks everybody!
