Load on rope / how to define a rope
PI_6131154
I have a case involving a beam structure suspended on ropes.
After analysis, I expect to see how the structure is balanced (center of gravity neutral) and deformed.
But I don't know how to define the rope correctly.
Could someone please help me?
Thank you in advance!
www.pi-engineering.at
10 REPLIES 10
here my model... was not attached
hm.. model can not be attached... hm...
pack all your files into one zip file and then upload it.
Martin Hanák
zip format is better choice.
Martin Hanák
Martin, I do not have ZIP.  It ist problem for you to dekompress the file? I can not unterstand the plattform and wy .prt will ot accepted.
Anyway...it seems that nobody knows how to represent rope in Simulate... 😞
in Windows you can zip file in File Explorer ... see following picture
Note:
You cannot upload prt0001.prt.1. You have to "send" it into zip file -OR- rename to prt0001.prt and then upload.
Martin Hanák
I have done it! Thanks. You can see below the file
now you can hope that someone will answer you. I won't, I'm not a simulation specialist,
Martin Hanák
