Locating Mfr of Seat Track
randyspeed
Hello group,
Forgive me for asking a non-ProE specific question, but I am trying to help a Texas company locate the manufacturer of the aircraft seat track shown below.
Does anybody know who makes this? Anybody I can contact to find out? Cargo Systems, Inc. is only a rep. of the product and is not willing to share the name of the OEM.
Randy Speed, Principal
Speed Consulting, LLC
2871 Howard Road
Waxahachie, TX 75165
(972) 938-0490 ph (972) 937-2319 fax
www.speedconsulting.com
Product #: Cargo Systems Inc. 40456-11
Product Name: Seattrack, Medium Duty, Per Foot ('Brownline' Style Track)
Product Details:
Vertical Load Rating(lbs.): 4500
Can Use With: Single Or Double Stud Fittings
Description: IMPORTANT:
If this part is intended for use on an aircraft, it is the responsibility of the owner or operator of the aircraft to ensure that a basis for FAA approval is obtained prior to installation.
All load ratings, breaking strengths and working load capacities are based on the manufacturer's published data. Cargo Systems, Inc. assumes no liability for misstated load values based on the manufacturer's published data.
It is important that all parts are used in the manner in which they are specified. Parts should be inspected prior to each use. It is important to determine if any possible damage or deterioration has occurred. Such damage or deterioration may include, but is not limited to, rust, broken springs, damaged 'gates' or keepers' on snap hooks, or cracking of the metal. If such discrepancies are determined, these items should be removed from service immediately
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
