MDO: Turning loads on/off automatically during a run?
titansfk1
I am trying to setup a simulate (sim) of a piston air compressor using
MDO. I am using a spring load to sim air compression. The problem is
how to turn off the spring force on the down stroke (intake) stroke, and
turn back on for the up stroke (compression) stroke. I tried turning
the force of after 180 deg (in Analysis def. Ext. load From:0 TO: .5), but it doesn't seem to care. I also have a
servo motor with a ramp position to rotate crank from 0-360.
Ultimately I want to add another piston 180 deg out of phase and then
look at the crankshaft torque requirements.
Steve krause
oakland, NJ
