Measure tool won't show SI
PantelisP
8-Gravel
Hello.
I am using Creo Parametric 8.0.0.0.
So... the title is descriptive enough. But let me give you some extra detail. So I have metric system on my file. The measure tool uses imperial system. It will show the correct value, (for example if I set something to be 10cm it will show 3.937inch) but the file is not on inch.
I went to:
File>Prepare>Model Properties
Model is indeed in metric system. Yesterday everything was fine.
Any ideas? Thanks in advance.
pushkarkhanna
(To:PantelisP)
Hello
You can change the units in the measure section regardless of units the part was designed
Please try this option
Pushkar Khanna
  • pack you file into zip archive and upload zip file
  • create new model and test it
Martin Hanák
There you go.
Had already tried creating new file. Old files and/or imported sketches with metric system, again, are being measured in inches in new parts with metric system.
I am sorry I cannot open your model because of this
Martin Hanák
pushkarkhanna
(To:PantelisP)
Hello
Pushkar Khanna
Martin Hanák
