Mechanism video is not smooth
GD_7177316
3-Newcomer
I am using Creo Parametric Release 4.0 and DatecodeM100
I have made mechanism and animation of engine component on Creo Parametric 4.0. I assume that there is some issue with frame rate because video is not smooth. Please extend your support to resolve this issue.
No error received.
Please show a screenshot of the error that occurs.
I am not receiving and error massage. I have completed my mechanism and animation without any error. while rotation engine parts using DRAG tool it rotates with intermittently. Can we have a call on same so that I can show you actual problem.
Gulshan
This shoud be resolution too low.
Set a higher Resolution to have a larger width and height in pixels of the output file or files.
Please refer to Help Center To Capture a Playback Result Set
