Please show a screenshot of the error that occurs.
I am not receiving and error massage. I have completed my mechanism and animation without any error. while rotation engine parts using DRAG tool it rotates with intermittently. Can we have a call on same so that I can show you actual problem.
Gulshan
"Open a Support Case": https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
This shoud be resolution too low.
Set a higher Resolution to have a larger width and height in pixels of the output file or files.
Please refer to Help Center To Capture a Playback Result Set
