Mechanism
sazzarello
2-Explorer
Mechanism
Creo Parametric 7.0.4.0
we recently upgraded to 7.0.4.0, my older version I was able to move mechanisms by hitting Ctrl+Alt+Left Mouse which was very convenient this new version does not allow me to do this, is there a setting somewhere to fix this or is it gone from the new version?
Hello @sazzarello,
Thank you for reporting this behavior with Creo Parametric 7.0.4.0 on your machine.
I ran a quick test on  my machine with a simple mechanism assembly and I am able to use the CTRL+ALT+LEFT mouse button to move the bodies from my mechanism.
Please can you confirm that the Drag Component command is working with your assembly.
PS: I ran the test  without config.pro and without connection to Windchill.
Jean Claude
yes the drag component command works as it should
@sazzarello,
Thank you for your quick reply and confirmation regarding  the drag command.
Is this issue  specific to your machine or are you able to reproduce on a different one with Creo 7.0.4.0 as well?
As  I  mentioned in my previous comment, did you check without your config.pro, config.sup and without connection to Windchill?
Jean Claude
I figured it out, seems someone else had the same issue, in the config.pro if you have enable_implied_joints set to no the Ctrl + Alt does not work to drag a component you either need to set it to yes or remove it. thanks for all your help.
@sazzarello,
Thank you for your follow up and the good news.
You are right. The config option enable_implied_joints is set to yes* by default.
This information will help other community members.
Thanks again.
Jean Claude
