Below is a screenshot of the error:
The element which causes the failure is inconsistent, i.e. if I run the analysis again, it might be another element which causes the failure.
I had wondered whether the issue was the constraints for the flap element which join it to the mainplane but I've tried bonded joints and adding an additional central fixing and haven't found a solution.
Currently the only constraints linking the flap to the mainplane are those within the assembly:
Not sure if these are sufficient to ensure the assembly works within simulation?
