Hi all,
I'm new here and I'm experimenting with Creo 2 for modelling organic shapes.
The freestyle function is awesome, but I'm having some trouble: I modelled a foot of my character and I want to make the other one through a Mirror feature.
The mirroring itself works ok, but if I modify the parent it doesn't update the mirrored feature.
(I cannot use Mirror inside Freestyle, the 2 feet are too far apart)
Having to delete and re-do the mirror every time is the option I would use in Rhino, not with Creo.
Am I doing something wrong?
Thank you,
Guido
Without having tried it out,
try mirroring the resulting quilt, not the feature! Simply change the selection filter to quilts and select the freestyle surface.
-> update: I can confirm it to work!
I am having the same problem if you find the answer let me know! Sounds cool, Id like to see your model!
Doh! Silly me not thinking about it before.
Thank you Constantin, I gave it a very quick try and it worked!
Thank you,
Guido
