Hello all,
I would like to simulate a column steel plate supported on a concrete slab. The load is in the downward direction so basically the steel plate induces compression on the concrete surface.
Material definition in CREO simulate, seems oriented to metals only? I tried defining the stress-strain relationship of concrete with 3000 psi strength but I haven't been successful. Is anyone aware of any work-around for brittle materials?
Thank you
This question comes up every now and then. Here's a previous question of a similar nature:
I would work with a safety factor of at least 1.5 (hooke's law)
