Hello everyone
I will write for the first time.
I am not good at English, so I am sorry if there is a strange expression.
In the sweep command, there is a tangent tab, but I did not understand exactly what role it would play for this function.
If there are easy-to-understand illustrations and samples, would you please teach me?
I am sorry to trouble you, but thank you for your consideration.
Hello mbonka
Thank you for your help.
I was able to grasp about "tangent" in general by referring to the items from the movie that I received and PTCU.
Thank you very much.
Hello @ykimura
welcome to PTC community. Try to search on youtube, there can be some usefull video tutorials.
https://www.youtube.com/results?search_query=creo+parametric+swept+blend
thank you very much.
I will check the movie you taught and check it immediately.
l´m not able to describe your question "in words"... some video can be better.
Hope it will helps
Hello mbonka
Keep in mind also that there are 2 different directions for "tangent", as there are for "normal". Depending on the boundary and what it picks, you could get some wonky results.
