P&ID Symbol Library
LeeCasey
2-Explorer
P&ID Symbol Library
Hi, I want to be able to create P&ID diagrams within Creo. Really, all I need is a library of the symbols so I can insert via custom symbol function within drawings. Does anyone have a library of P&ID .sym?
jrichard
(To:LeeCasey)
Lee,
I was looking for the same thing one day and found that there are symbols available for download on the PTC site. Just go toPTC Software Downloads > Creo Parametric & Pro/E > Release Wildfire. Under that section you will see Wildfire Library Databases. You can download all the symbol folders and then use these in your drawings. I did this with Wildfire 5 and it worked just fine. I can't see why it would not work with Creo.
If you have a license for RSD, I would guess that comes with an extensive library of symbols. If not, this method works. Hope this helps,
Jon
cschmid
(To:jrichard)
I cannot find the location of this library.  I think this message is outdated.
