Hello All,
I am trying to simulate effect of wind load on glass railing holder which is fitted to ground via. screws. so after defining the constraints , contacts and loads when I review the results I observe that the glass holder penetrates into the ground. see attached screenshot.
Can you please advise why is it so and how can it be resolved? I would appreciate your help with it.
Please upload STEP data.
What is the second picture of exactly? Is that the displacement result? If so what is your scaling factor?
You say that the railing has "contact" with the cement. Exactly what constraint are you applying there?
How is the "fastener" being defined? Is that a solid model? Is that a Simulate fastener? Spring or beam element?
Hello @Chris3
Thank you for your response. I have attached a pdf for detailed explanation.
1. Scaling factor is 10% see page 13
2. I have defined contact interface between railing and cement: see page 10
3. Fastener is a simulate fastener: See page 11
Please let me know if you need any further information.
Some comments:
1. Your loads are in metric, but your last slide is in psi which is confusing. The last slide that shows the deformation is not in units of length so its impossible to tell how much its actually deforming.
2. Not sure if your UDL includes the 1G weight of the structure, but if not you might want to consider that load.
3. Fasteners are not good at carrying moments by themselves. If you look at other railing designs they usually have a 4 bolt pattern so that when moments are applied the fasteners go into tension. A quick hand calc with a moment applied to a single fastener will demonstrate this for you.
4. I have not used the component to component contact myself. I would suggest changing that to be surface to surface. Contact surfaces work by adding springs in between the surfaces and then iterating increasing the spring stiffnesses until the parts don't interfere anymore. If this isn't working for you, you could always just add in springs yourself. Be aware though that very short stiff springs can cause FEA to produce incorrect results.
Hello HV_11420821,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
