Parts are flying even after creating contact in Creo at 0Hz in Modal analysis
NR_10501208
8-Gravel
I have created washers and given contact between washer and abutmant with friction 0.1. Still the washer is flying at 0Hz in modal analysis
skunks
(To:NR_10501208)
Modal analysis is linear, but contacts are nonlinear 😂
8 REPLIES 8
skunks
(To:NR_10501208)
I am getting the below error when I am trying to use non linear option
skunks
(To:NR_10501208)
yes, large deformation analysis is non-linear.
some non-linear options cannot be combined
Can't the model run with shell elements? I removed shell and made it solid then model is running.
skunks
(To:NR_10501208)
shell elements are linear in simulate 😂
Thank you for your time. You have answers for everything in Creo. Are you the one created this??
skunks
(To:NR_10501208)
😁 no, I started with (Pro/MECHANICA) in 1999.
The programming was done in 1987: PhD Richard B. King, PhD Christos Katsis etc. later PhD Tad Doxsee (Shells, ...)
I figured we were similar vintage. 😁  I started Pro/ENGINEER 1996, Pro/MECHANICA 1998
