Point Constraint Values Unreadable, Increase Size
Beuk
Whenever I print to pdf, the point constraints result plot lose part of its resolution, making them close to unreadable. Is there a way to increase the font size of those particular fonts bigger?
I have tried playing around with these config parameters with no luck:
default_ui_font 10
text_height_factor 40.000000
model_tree_font 10
7 REPLIES 7
Beuk
(To:Beuk)
I managed to change the fonts of the menus, but the point constraint values stay the same.
skunks
(To:Beuk)
I don't know how to change the font size,
but I always use measured values on springs to ground for bearing reactions.
tutorial
cf. page 39
skunks
(To:Beuk)
my workaround in creo simulate 2: screenshot
Beuk
(To:skunks)
Thanks for your anwser skunks.
I am using Creo 10. I have swapped one of the point constraints for one "spring to ground". How do you manage to now see that spring force / ground reaction in the result window? Only way I can find that value is by using a measurement.
skunks
(To:Beuk)
skunks
(To:Beuk)
--> Creo data as an example
Hello @Beuk
It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
