Hi I am not very sure about university edition, but The problem might be with installation. When you are installing the Mechanica module, you need to refer the address of Pro/E start up directory. This is how the relation is established b/n the Pro/E and mechanica module while you try to invoke the mechanica in Integrated mode. I suggest you to install Pro/E first, then again run the set up and now check the button of Mechanica module, and run the set up. At some point, I don't remember exactly because I used to install Mechanica years ago, so just a try, it asks about the license file and pro/e startup directory, where you need to refer the firstly installed Pro/E. If I can do anything else, please let me know. Shekar
