Redefine simp rep in pro-engineer Wildfire3
mboubault
Hi I have created in assembly a simp rep in wilfire3, and I can't redefine this. The command redefine is blank. Could you help me. In most assembly the function is available but not forever. Thanks
FM
(To:mboubault)
Hello Mikaël, Did you try to create a new one and redefine it? Does it works ? Is it an assembly instance from a family table ? I've already notice that in an instance you can only select one rep simp in order to active it but you can't redefine it. This is only available on a generic assembly. Bye Fabien M
