Regarding circle pattern
SM_10342271
Hello everyone, I would like to know is there any possibility to make a pattern like this. I just want to create one circle and the remaining circle i would like to create as a pattern. For your reference i have attached the image, please have a look. Thanks in advance.
@SM_10342271 wrote:
Hello Mr. Hanak,
What if i create one sketch and use the revolve option to extrude. After that can i create a pattern for that extrude in such a way?
yes, you can use such "procedure". You do not need Sketch feature. Simple create first Extrude or Revolve feature and pattern it.
For example:
Martin Hanák
in Sketcher you cannot pattern entities.
You can create Sketch feature and pattern it.
Martin Hanák
Hello Mr. Hanak,
@SM_10342271 wrote:
Hello Mr. Hanak,
For example:
Martin Hanák
I have tried this option and its working now. Thank you for your help.
