How to run simulation using higher number of cores?
please ask PTC Support.
ANSYS allows end users to select number of cores to run simulations.
If you are running Creo Ansys, there is a configuration option, put in your "config.pro" file to specify the number of cores. From the list of options:
creo_ansys_solver_cores <number>
"Set the number of processor cores to be used by Creo Ansys solver. Currently Supports 1-4 cores."
Default value is 2.
Apparently, if you're using Creo 9.0, this setting is available in the user interface, as discussed here:
UI Setting of Cores for Ansys Simulations
If you're running Creo Simulate (not Ansys) I don't know how many cores it uses, but I see there is a config.pro option for Creo 9.0
sim_run_num_threads <number>
This option will "Specify the number of CPUs that Creo Simulate Native mode will use for running the analysis. The possible values are: ALL (default), ALL_BUT_1, ALL_BUT_2, 2, 1, HALF. "
