SUMMARY: Easy Wildfire 2.0 Question.
unknown1
Every answer I got to this question was similar to this one:
I think you have to use the Search tool now instead of Select by menu......
Pick the binoculars icon from the icons at the top, it's pretty robust,
there are a lot of options in there and you can do a lot.....that having
been said, it's a little intimidating, I wasn't very comfortable with it in
the beginning, but I'm used to it now.
When you are in the middle of assembly, just hit the icon, search for the
datum you want, and when you are finished in the dialog, it should
automatically select that datum.
Thanks to all who responeded.
John Suyes, PE
Design and Development Engineer
Hill Phoenix, A Dover Company
1925 Ruffin Mill Road
Colonial Heights, VA 23834
(804) 451-2455
(804) 526-1926 fax
John.Suyes@hillphoenix.com
Confidentiality Statement: The information contained in this transmission is
privileged and confidential. It is intended only for the recipient(s) named
above. If you are not the intended recipient, please forward this to the
intended recipient immediately. Anyone other than the intended recipient is
strictly prohibited from any dissemination, distribution or copying of this
transmission. If you have received this in error, please contact the sender
immediately and destroy the transmission.
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
