Q:When you "save as" a file you have all the different types to which
you can save besides default Pro/E. I recall reading that you can change
the order(First is IGES, then set.....No.7 being DWG in the list) in
which these files types are viewed, via a config-if anyone knows please
could you contact me, Cormac
A:Set preferred_save_as_type to the file type in your config.pro.
