My company just switched from ProE wildfire 4 and we use draft entities alot for background gemotery. One of the biggest annoying things about Creo is having to hit and hold ALT to select enties when we want to delete them. In Wildfire 4, Pro-E would see that it was a entity and you could click on it without having to hold the ALT key down. Is there anyway to get function like Wildfre 4?
If you go over to sketch you are able to select the entites
