I'm looking for an example of how to setup a flow analysis of a server rack. The server rack has external air flow inside the rack then directed to specific servers which includes fans and the directed to an external exhaust air outlet. I have not been able to find an example of a flow analysis model resembling this. Is there anyone that has an example they could share or point me too.
Welcome to the PTC Community!
Thank you for your question. I’d like to recommend bringing more details and context to your initial inquiry. It also helps to have screenshot(s) to better understand what you are trying to do in your process. This will increase your chances to receive meaningful help from other Community members.
Hi
That is very simple using creo flow analysis, try watch the external problem tutorial and you will get the idea. Thanks.
