Side loads on beam model
PI_6131154
Hello!
I have a frame design.
I wish to get the reactions on the 4 points.
I have as load the gravitation.
The "Y" Reactions are ok.
Way I get also reactions on "X" and on "Z"?
In case that I have on corner "1" and "4" NO translation and on the corners "2" and "3" translation, by using of load by side, I will not have reaction in the corners "2" and "3". So ...this is the art to determinate the forces, but this is wrong be side load. So ..how to set the constrains correct?
Thank you!
www.pi-engineering.at
Hi @PI_6131154
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
