I have a circular beam with fixed bearing (on the left) and simple bearing (on the right),
my problem is modeling correctly the constraint of the simple bearing.
Thank you for help.
You did not mention what analysis you are attempting (Mechanism or FEA structure). This article may be helpful.
http://support.ptc.com/cs/cs_25/howto/mst6864/mst6864.htm
It's not a mechanism,: it's a solid part imported from Creo Modeling
