I have built a model of a planetary gear set in Pro/E and correctly (I believe) modeled the connections. However, when it comes to defining the gear meshes, I have no problem with the sun to planet gears since they are both supported by the planetary carrier, but the planet to "universe" gear connection do not share a common carrier. As a result, the relative motion between the planet gears and the universe gear is not correct, it skips teeth. Does anyone have any experience with this? Any tips would be appreciated. Thank you.
