Anyone know if it is possible to hide the transparent lines (see image) in Simulate Results after I have made a cut/section. They are annoying when I want to take pictures for report.
Stale
I agree it's annoying, but I don't think you can get rid of them.
I think it is possible to get rid of these lines if you post-process your results in the old Pro/MECHANICA Independent mode. Unfortunately we seem to have some license server issue at the moment, so I can't verify this.
A workaround is to create volume regions of your model, and then in your post-processing, you can choose to display results only for the volume regions that you select.
/Mats L
/Mats L
Thanks for great information Mats
Stale
