how can i simulate the mechanisms using gas springs . Can i use gas as a medium to apply pressure on the piston. how to simulate that kind of situations.
Thanks in advance.
Hello
We could imagine a spring including the K to the report of the compressed air.
Kind regards.
Denis
Hello
Here is some information if this little help.
Kind regards.
Denis
http://www.vapsint.com/fr/fonctionnement-et-caracteristiques-des-verins-a-gaz/
http://www.skf.com/binary/12-122047/5507-2-FR_Ressorts-a-gaz-STABILUS.pdf
Hi denis..
Thank you for the reply . Its helpful and ill go through them and get back if i have any doubts. But how can i apply both dampening and springs at a time in PTC.
